I'm trying to set my carburetor float on my 1976 Mercury 500 carbs. The float needles have springs. The float levels were set at 1/4" when the float was manually depressed to where there is no more "spring" but the float level is twice as high when the float is resting with just it's own weight against the float needle/spring. I'm thinking this was done incorrectly by PO and the setting should be set at 1/4" when the float is simply sitting with it's own weight resting against the spring. The service manual doesn't comment on this spring phenomenon. Can anyone advise on the appropriate way to deal with this? Thanks.
