mercury 50 outboard trouble
zabee
recently serviced and ran well first time but recently had trouble with it dying when giving it revs. only thing i changed was the oil mix. Being an older motor should the fuel-oil ratio be different ?. mixed 50-1 with caltex super 6 with a little bit of a better result but problem still persists.
Laddies
Banned
Re: mercury 50 outboard trouble
You forgot to give the year of the engine if it's neewer that 64 it's a 50 to1 engine it sounds just a little lean off idle.
zabee
sorry i couldnt find the year. I have the serial number 6421705 but cant find the listing for it. Do they have an idle screw on them somewhere?
trussmonkey
to find your year (goto)
maxrules-
tech specs-
model year guide-
yes, it has an idel adjustment screw (needle)
Laddies
Banned
It's a 1983 engine-
This is not excatly your carb but the idle needle is the same.
zabee
Thanks for all your help guy, cheers
zabee
the boat idles at about 1000rpm but dies when it sits on about 1500rpm. messed around with idle needles a bit but still dies. if you give it revs real quick it seams to have no problem. It sort of sounds like its flooding. takes a bit to get started after it stalls. any ideas?
trussmonkey
:confused:What mix were you running before?:confused:
when is the last time the carb was cleaned?
(possibly a stuck float) does fuel continually run out of the carb when you pump the fuel bulb?
zabee
yes fuel will continue to come out of the carb when pumping the bulb
zabee
may have run bad oil through it second time checked it and it was a browny colour. could this have faulted one of the spark plugs ?
Laddies
Banned
If fuel keeps running through the carbs you have a inlet needle sticking
