Re: Mercury 4hp stroke whirring noise
Thanks. The serial number and other data puts it as a four stroke. Some careful listening and trying to pin point is needed - tricky. But first, check the oil level and state of oil. I'd do an oil change too, checking for the presence of metal filings in the oil visually and with a small mechanics magnet. Replace oil with the best you can afford. I'd also take a look at the recoil starter to see it it's not hanging up or something's rubbing ..unlikely, but you never know. Could be noise coming from under flywheel too. Go to "**********" and search for your schematic to get familiar with your motor.
If you have a mechanics stethoscope it can be useful to try and pin point noises ...or use a long screwdriver and listen at the handle end, touching the tip around the engine...watch out for moving parts always. Check lower unit oil in case noise is coming up from below. Keep us posted.
