Beware_of_Dawg
- Oct 25, 2013
- 4
Hi everyone! New here... I have a few questions and hope to get some advice/guidance.
I purchased a used 4HP mercury outboard. I was told by the previous owner that it hadn't been run in awhile but worked perfectly. I have no reason not to believe that as he is a neighbor who also offered to give my $$$ back if I was dis satisfied.
The engine is spotless. It's not brandnew, I suspect it's somewhere between 5-10 years old. I don't have the serial numbers with me right now.
I was told by someone else that I should go a little heavy on the oil/gas ratio the first time I ran it.
So it wouldn't fire initially, I changed the plug out and it fired up after a few pulls.. idles a little rough (shakes a little although I have it lossely mounted to a large plastic trashcan filled with water and Im not positive what "normal" is as far as the idle shake). I let it idle for a few minutes, revved it up pretty high a few times (initially it did bog down when I punched the gas, perhaps not warm enough? Again, Im not sure if this is normal)
Because I was advised to run heavier on the oil mix initially she smoked pretty bad but fired up easily the next couple times. I'm eager to get it out on the water (12 foot john boat) and do some fishing. Last night I started it up, it fired on the first pull but stalled out and now it won't fire up at all. I thought perhaps I flooded it, so I let it sit for an hour and tried again... nothing?. I did the same thing again this morning, and nothing it wont fire at all.
I'm fairly sure it could use a carb cleaning, are there any instructions you guys can offer on that? Would spray cleaner do the job? or can someone instruct me as far as what could be the issue and if a "full clean" of the carb clean can be done fairly easily myself or should I seek a professional to tune it up before I attempt to put it on the water? How much should that be? I have a big fishing trip planned for tomorrow morning and hoped to get it out there...
Any advice, or guidance for a new / outboard ignorant owner would really be appreciated!
Thanks for everything in advance
David
David
