I found out from a local dealer the outboard is a 1986. I may have a problem with the fuel line filter or pump. Where can I see a diagram of this engine as I need to find the choke arm which has broken off?
>> I have a 4hp Merc 2 stroke serial #A907218 and am looking for information on this outboard. I am trying to start it and have only been successful at getting it to partially start by spraying starting fluid into the spark plug hole. As soon as that is burned, the engine shuts off. The primer bulb is firm and gas seems to be getting to the engine.
Along the way I also broke the choke arm when replacing the shroud. Where can I get that part and what's required to replace it. It looks pretty daunting.
Many thanks for your help!
