Re: Mercury 40hp Prop specification
Hi,
I have the following info:
length at water line 13.4 ft/4.02m
displacement 500kg/1100lbs/.49t
single outboard engine
40hp
5300 max rpm
gear box ratio 1.7
I have used some software that calculates a 10.60 prop diameter with 11.15 pitch.
The pitch alters depending on what you input for the hull type ie full displacement, semi displacement, ski boat
I am unsure what to class the boat as???
