Hi thank you very much for your reply! Does this happen to be this in the photo as some are located on the rear of the engine where the plugs are aren't they ?Likely a Leaky Water Jacket Cover Gasket and/or Warped Water Jacket Cover.
Seems to happen a lot on engines that get a little too Warm, too many times
OrReplace gasket as stated above.----Might as well do your friend a favor and replace water pump impeller.
So this is the water jacket area that may need attention? Thank you very much for your help !OK Sticker/Decal, is just an Engine Test Run was done at the Factory. Which on this engine, was about 50 yrs ago
Are the Spark Plugs there?So this is the water jacket area that may need attention? Thank you very much for your help !
No, spark plugs are not in the area I pointed too that's why I am asking, what I pointed to might be the exhaust portionAre the Spark Plugs there?
Here is my 84 115, getting the same repair
This is what the 402 40 hp looks like then ?Are the Spark Plugs there?
Ok, I will get it for youSerial# is needed.
Yeah, I saw the Philips screws in the bottom, will do, thank youYep, that is the cover that is leaking if the water is coming out by the Spark Plugs. Hopefully you won't break any of the Bolts that hold it on. You will have to remove the Parts of the Cowl Support Frame(front and rear) to be able to tilt the Lower Cowl to access the bottom of the Jacket. You can see how I had to tilt it to gain Access.
Thanks for the heads up, I have one comingThink they are NLA. Check EBay.
