Mercury 3 ram tilt and trim problem
Tman65
I have a black max xr2. The 3 ram tilt and trim moves up and down good and stays up. But I can grab the motor and pull it down to the trim cylinders. The tilt cylinder will not hold force. It will drop slowly. It held last year. Some people say o rings are bad, just replace them on the tilt cylinder. Some say wow there are 20 little valves and seats in there and a real pain to fix. Find a different one. Some say a change of fluid will fix it. Dose anyone know the answer? Or how to tell what to fix? Thank you.
Faztbullet
if you can do it with little effort the impact valve leaking in cylinder...the little balls
