Help, I have just encountered some type of ignition failure on my 1995 25 HP 2 cycle Mercury outboard 0G153788. I had just had the boat out of the water and did a water pump service, lower unit oil, and new plugs.<br /><br />Motor started up as usual took out on a slow cruise and 10 minutes into the ride at about 1/4 throttle the motor dies just like I hit the kill switch. No spark, no fire. <br /><br />So, this motor seems like a rather simple ignition system, however I have no idea on how to diagnose. I assume that the problem is either the Stator the Switch Box. I find it hard to believe that both coil's would fail at the same time.<br /><br />Any one have a simple diagnosis procedure for checking out and isolating the problem component?
