Mercury 25hp (5842749 serial #) Locked up.
Roberthill
Just got this motor running , 120 psi compression both cylinders, plenty of oil mixed with gasoline, ran it several times in a barrel , shifted fwd and rev , then tried starting ,motor was locked , wouldn’t budge. Does have electric start , took off pull rope starter and tried turning with both hands on flywheel, would not budge. Does anyone know why this happened? Any help would be appreciated.
QBhoy
Pull the plugs out it. Try it. Or is the starter stuck on the flywheel
