1999 2 stroke. No tell tale , lower leg lines clear, new impeller kit correctly installed. When on muffs and running water comes out from under power head. Removed powerhead and see no signs of gasket failure. Thermostat working fine. Very little carbon build up. When I first removed prop there were chunks of carbon behind hub exhaust. Anyone ever have this issue? Freshwater used only. Thanks in advance.
