natecollins1
- Jun 30, 2006
- 37
Hi,
I have seen were several people on this forum have had similar problems with Mercury 25 hp 2 strokes having trouble stalling out after several minutes of running unless the primer bulb is pumped. I am having similar problems. I have cleaned and rebuit the carburetor and fuel pump. I checked all carb passages and they are clear. I rebuilt the fuel pump first with just a new gasket and diaphragm and then again with a new pump body (valves). I have changed hoses, fuel tank and fittings with no cure.
Has anyone been successful at finding a solution to this problem? It appears that the fuel pump is not pumping enough fuel, but unfortunately this fuel pump is cast into the carb and does not have a pulse line coming off the crank case to help move the diaphragm. Any answers from someone who overcame this problem would be greatly appreciated.
