Mercury 200l efi fuel leak
TroopBoat
So a quick break down on what is going on. I have a Triton tr-20 that I got from a family member who passed away. I believe it's 1999. The boat was sitting for 4 years so I drained all the gas, changed the fuel filter, plugs, lower end fluid, and went through all the wiring (and new battery). Once she looked good I hooked up the water and she started right up. I immediately noticed fuel pooring out of a fitting with a hole in it. I will attach pictures of the fitting. It's right under the oil tank. I also did not see any water coming out of the tell in the back, but she was only running for less than a minute. I did take off the hoses and attempted to use carb clean in there in case something was stuck, but do not see anything. Any ideas out be great, thanks!
Ryan
Dukedog
VST vent.. ya have something outta whack in tha vst.. ie: stuck needle and/or seat.. bad float.. trash etc.. reason for tha "hole".. lets ya know something up!
Faztbullet
Dang Duke beat me to it!!!! Most likely VST float is stuck down....
