Have 2002 90 hp merc injected 2nd owner , oil consumption is too high, i am past cert. marine mechanic. (omc tohatsu )I need adjustment procedure for linkage.Mixture is to rich at idle causing missing and hard starting.I have 2 marks on the pump lever and one on the pump casting. which one do you align with at idle position.Rod is extended out very far ?. thought is dealer set mix rich at delivery for break in .
PS: almost 3 gallons oil at 90 gallons fuel
