GWDolphin253G
- Jun 12, 2009
- 6
I am rebuilding this motor and everything has been going smoothly so far until I have been thrown for a loop when I tried to close up the crankcase. All new pistons and rings are well lubricated and sliding smoothly on new bearings that have been put together on correctly aligned rods that are torqued with new bolts. Crankshaft is freshly polished and has all new main bearings and seals too.
At this point the end caps are on but not screwed on to the top half I am about to install and torque down. Everything still turns beautifully. I install the crankcase cover and torque the large bolts...all good. Same with the smaller bolts...still all good. I go to torque the end caps and the turn gets really tight. I loosen the end caps, and it turns smooth again.
I have looked for a problem and have inspected everything but I cannot figure out what I am doing wrong. I measured and micro-measured clearances and everything checks out. I installed the lower main bearing with the lettering facing down and up with no change. Both top and bottom o-rings sit true and are not caught or causing undue pressure.
Someone please tell me that I am a dumbass and have overlooked something minor.
Thanks!
Thanks!
