Mercury 1997 75HP no spark 3 cylinders
raczekp1
I'm working om Merc 75hp 3 cylinders with no spark.
Where can I find Ohm readings spec for stator and triger.
triger has 4 wires going to inside : brown -white, purple-white/black
what resistance should be?
CDI Tech Team
Resistance values of stator would be 3,250 - 3,650Ω on Blue to Ground and 75-90Ω on Red to ground if OEM Trigger would be 800-1400Ω from the Brown,White, and Purple to the White/Black
Faztbullet
Check to may sure the kill lanyard is hooked up and drop the blk/yellow from switch box and retest with plugs removed. If still no spark it usually the stator or switchbox.
raczekp1
I did stator resistance test : 5 wires, 2 yellow, 1 black, 1 red, 1 blue
black wire to red =145 Ohm
black to blue= no contunity
So stator is shot?
bstig60
I have a similar problem on my 95 Mariner 90HP engine.... Are the resistance numbers for the stator the same? I have looked at CDI Electronics and have not found resistance readings, just voltage readings, some of which I can't check because I do not have the proper tools.
raczekp1
blue cable was broken just few cm from stator outlet. now is fixwd. stator blue to black is 6000 Ohms.
I send CDI switch box to repair shop. they fixed cdi switch box and now i got sparks on 3 cyl.
i run motor but i can hear thicking sound from top cylinder.i dont know if its normal
