i never had this boat running. but previous owner said it just need carb work and ran last year.
i pulled the carb off (3 of them). it looked like sumone already rebuilt the carbs had a new needle in it so i ended up not replacing anything, was going to rebuilt. so i just ended up cleaning it out. some of the screws i couldnt get out to clean and the weldge plate i didnt know how to remove.
this is my first time.
i manage to put everything back in and i couldnt get the motor to start. cranks great and has spark. the fuel is what im worry about. when i spray starter fuild the engine seems to fire just alil, had alil smoke come out but then nevers start. the more starter fuild the better it sounds to start. but still never start.
so i began pumping more fuel in and on the enrich valve pressed a button for 5 to 6 secounds and tried to start. nothing.
i just wanted to see if their was fuel in the carb so i over pumped the line till i saw fuel come out of the carb. it came out where the pipe points up.
i then hit the trim just to see if fuel was coming out and it was.
their is no kill switch.oh and the idle screw i screwed all the way in and about 1/8 out. i tried 1/4, 1/2, 1/8 etc.
and i also tried putting the throttle half way still wont start. the vent on gas tank is alil open.
is their anything esle i can try.
i might even buy new carbs if i know its the problem
