Mercury 150hp
kevinengland70
I have a 150hp mercury. #2 and #6 was not firing. I replaced the switch box and they are now firing. But now #1 is not firing. Ughhhh!!! So now while trying to figure this out we turned the key and nothing. Just to make sure the battery just didn't die I tried to jump it off and still nothing. Something happened to the ignition. Anyone with any ideas please help.
kevinengland70
Re: Mercury 150hp
ok checked the fuses the 20a and the 30a are good. The only other fuses i see are 2 relays underneath the steering. Im new to all this so should I replace both of them? Could the ignition switch have went out just that quick?
kevinengland70
Re: Mercury 150hp
fixed the ignition issue all i can figure out is it wasnt all the way in neutral. newbie mistake, also fixed the firing issue i had by replacing the switch box
