Re: mercury 150 xr2 blackmax (1985) sn A157375
Sounds fuel related! Did you try pumping the bulb when you are wot? If the motor perks up it's a fuel pump problem. Could also be a carb problem. Comp #'s aren't bad, thats good! Good luck let us know!<br />CU<br /><br />--------------------<br />RUNNING THE MOTOR WHILE LISTENING TO THE HORN WILL MAKE YOU MORN!!
