I have inherited a 1978 Ranger Aztec w/ Mercury 150 ( Black Max ). After a few trips to the water and trying to figure out
what is causing this motor not running to its full potential. The motor is very slow to plane off, but once on plane seems to
run fairly well, will very rarely ever have enough power to load it all the way on the trailer when backed in at boat launch.
Here is what I have found so far; (1) the tach didn't read the right rpms so I traced it back to the rectifier and sure enough
the rectifier was shorted, so I replaced it, tach worked properly for a while then back to same. I have removed the stator
and of course it is shorted out as well, so I have now ordered a new stator ( from iboats ) and am curious now if when I
install new stator and rectifier that if by chance my switchbox and/or trigger is shorted out as well is it going to fry my new
stator? Is there a way I can bench test the trigger and switchbox before I go any father with this?
Thanks for any help here...
