Mercury 150 EFI cutting off randomly
keebs
My problem consists of my outboard cutting off while im running..
The speed varies when the motor cuts off.. I can be going 15 or 50 but the motor will cut off a some point and its always randomly..
I can run sometimes for a while before it does it but sometimes it happens right when i head out..
But the motor will crank right back up..
No alarms for overheating sound..
sschefer
Re: Mercury 150 EFI cutting off randomly
Tough to call.. I would guess water in the fuel.
letsgocanes
Same problem hear but with the 250 proXS.....Getting a "STAL" code in the digital display. But I am having the same exact problem. May have it looked at tomorrow and whatever the diagnostics return I'll let you know.
keebs
Please let me know what you find out
merbill
had similar problem with my 150EFI. found that filter on fuel pump in VST required cleaning after which, no problems. You also need to replace the O ring, as it stretches and the old O ring won't go back on and seal.
Faztbullet
Sounds like high pressure pump my be failing or loosing voltage from ECU.
keebs
Alright, Thanks for the replies.. I will let you know if we can figure it out.. Its driving me nuts!
72searay190
sounds like a simple fix, but definitely something to look at... I had this similar problem with my 1976 Merc 1500... My fix was a loose connection at the terminal block..... Check that they are tight and the vibration didn't loosen them just a bit.... Under Power, it breaks connection because it's loose and rattling.... sitting still, no vibration, good connection! Hope this helps!
keebs
Water in the fuel has been ruled out..
merbill
check the fuel tank for items that could possiblely be drifting in the bottom of the fuel tank. As the fuel is drawn up through the intake pipe an object may block the pipe at the bottom of the tank, the motor would then use the fuel in the fuel line and then cut out, the object would then drop off and you would be able to start the motor and again the object would be sucked up blocking the pipe. you would again be able the run for awhile using the fuel in the line before stopping again.
