fvmarauder
- Jun 2, 2010
- 4
I have a 1974 Mercury 1150 115Hp dirtect charge thunderbolt engine. It currently won't charge my battery. Could frayed wires cause this? Or could anything else besides a bad stator cause this? Thanks!
The wiring to the battery is bad? If so, itlikely blew the rectifer. Merc Rectifiers are $50. Aftermarket equivalent are $25-30. Radio Shack has a 25A Full Wave (Bridge) rectifier which is superior to both, for $5 or so. To use it, you need to change the Merc ring terminals to spade terminals, and ground the -DC pole on the rectifer to the motor casing.
BTW - fix the wiring from the rectifier to the rest of the wiring harness.
