Mercury 1150 Fuel Pump Lines
mjbates01
I have a line on the bottom of my fuel pump that has come loose...has a one way check valve....also its a small line that goes to the bottom of the fuel pump,...any help is much appreciated
Chris1956
You might post a picture. There were at least two different fuel pump types. There were dual fuel pumps mounted on the transfer covers and single fuel pumps mounted on the lower cowling. I cannot tell which you have from your description.
It sounds like you are looking at the oil recirculating line from the bottom main bearing to the top main bearing. That runs next to the carbs, and is much smaller than your fuel line.
