Hey Everyone,
I have a 1971 11150 mercury inline 6 motor and i have a few questions. First is my wide open throttle is about 3500 rpm does anyone knwo why. When i look in books it says it should be 5500 rpm. My other question is i have a 2 blade prop on it i think that is factory. Should i put a 3 blade and what size and pitch do you recomend?
My last and final question is when i pull away from the dock and get going it seems like the first or second big wave i hit the moter will bog down and we will slow to a stop a then it will cut off. I will then pull my warm up lever up and crank it and go again maybe never to have a problem till later in the day when i crank it after it has been sitting and is cold again. When i am going accross the lake pretty good i get greedy and give it a little more gas and it will pick up and go for 30 sec or so and then bog down and i will have to stop and start again. What does this sound like if i just get at a good cruising speed and maintain it and never give it any more gas i will be fine.
I have replaced all the gaskets in the carbs, the 2 fuel pump diaprams, and the fuel line going from the fuel tank to the front of the motor. Can anyone help with my problems any info would be nice thanks.
