Mercury 115 / 90 Jet Rev Limiter
Knot Paid IV
My merc 115 / 90 jet at top rpm’s hesitates and drops about 200 RPM’s then within 2 seconds goes back to 5,100. For the sake of time I’ll leave out all the things I’ve attempted to check, fuel lines, air leaks, CDMs, voltage regulator, etc. I am being told by a certified mechanic that the next thing to checkout my rev limiter. For whatever reason I can’t find it on the engine I know there is one due to it being a factory jet. I’ve see it on wiring diagrams but none show where it is actually located on my engine. Does anyone have a picture of where the Rev Limiter is on a 115 merc Jet? Everybody so far that I’ve asked confuses it with the voltage regulator.
Manufactured ID 0G738326 model 115472UD
Texasmark
It's the same shape and size as the voltage rectifier/regulator module and is located on the same side of the engine. It's down low, just above the midsection centered on the engine L-R. The oil tank may be hiding it. Proof in the pudding is that it has a brown wire (among others) that is the brown wire to the triggers to kill them when too high.
QBhoy
Are you sure it’s no cavitation caused by a poor impeller to wear ring clearance ?
Knot Paid IV
I’m pretty sure it not a cavitation issue. My problem is that the engine looses rpms. Also, I can intentionally over trim my jet and that cavitation revs the engine.
Ill look under my oil my oil tank when I get back on the river this weekend.
Knot Paid IV
Still can’t find anything that resembles a rev limiter. Any body have a picture of it’s location on a merc 115 jet?
flyingscott
Are you sure it's not part of the switchbox? Are you sure your motor is a factory jet?
Texasmark
Get a brown wire from a CDI/trigger/HV module and follow it around the engine. If you have a rev limiter, sooner or later the brown wire will take you to it.
