Hydrasports1750CC
- May 24, 2011
- 3
Long story short, ate up up a piston last summer due to poor carb maintenance.
Stripped the motor to the block and installed a new piston, engine runs great.
Roughly 20 hours on it + or -.
Now the motor has a distinct metallic rattle coming from the midsection / gearcase which occurs when the motor is off-load but at speed. This rattle occurs when slowing down gradually from planing speed and is intermittent. It does not occur when the engine is under load.
This noise is not emanating from the powerhead as i cannot replicate it in any way without the boat being under load.
All bolts / fasteners on the motor have been checked, tightened and rechecked and I am running an aluminum solas prop with the hub locked down as tight as it will go.
Any advice is appreciated, I am nearly to the point of vibration dampening the drive-shaft with a pneumatic rubber hose but it just doesn't seem necessary.
