Hi all, need some help!
The motor is a Mercury 110 9.8hp with type 2 ignition system. #1 hole (Top cylinder) is dead, ( I started engine with #1 plug disconnected & found no difference in performance then when connected) I checked compression and have 110psi both holes, when I remove the plugs #1 is wet & clean, #2 is wet & black. I have good spark on both (Removed plugs, grounded & pulled on starter rope a couple of times & saw good sparks both holes) I also checked the points as per my Seloc manual.
All this testing was done in driveway with motor in a bucket.
I just replaced the fuel line from pump to carb, I replaced the factory line with hose barbs & hose clamp, The ID of the new line may be larger then factory.
Thanks for reading.
Thanks for reading.
