2001 mercrusier 5.7L engine, 200 hours, maintained well, freshwater flushed each use, I had a hard time starting the engine the other day. Finally started, spitting and struggling for a minute or two, then settle back to a normal idle.
When out on the water and when traveling over 3000rpm, I would hear an occasional violent bang or knock. Not consistent with anything except speed over 3000rpm. Could not reach normal speed of 42 mph (only 35) and could not get over 4000 rpm (normally 4500). Idles perfect and accerates fine. Just the banging every once in a while. (only under load) no change in speed and no influence from water conditions, I have changed plugs (perfectly normal) and fuel filters. Still having same Bang/Knock. I have a bravo III, checked for leaks end of last season and replaced lower unit old (normal) Any thoughts on this problem
