ddunlap257@gmail.com
- May 11, 2014
- 3
I have MerCruser MCM-170 Serial #0A475016 with a trim pump SAE-J1171 Marine. I have had problems with trim drifting down will running in the water and on the trailer when it was up. I am not loose any oil. It has been doing this for several years. I figured that there was an o-ring or seal leaking in the pump because I was not loosing any oil. I recently took the outdrive off to have the bearings replace. While the outdrive was off one piston went all the way in and the other one most of the way out. I have tried putting pressure on the one that is out to get them back in sync and it would not moved. When I push the trim button all I here at the pump is a clicking sound like a solenoid trying to kick in. Nothing happens. Is there a service manual for the trim to take it a part and replace the o-ring/seal that is leaking and to get the pistons aligned again?
