Re: Mercruiser vs Crusader
Crusaders have traditionally been better engineered from an accessory standpoint (risers, manifolds, closed cooling, etc.). The engine blocks, heads, parts, gaskets, etc. are identical. All the manufacturers buy the same engines from GM with only one or two options. Crusader used to be owned by Thermoelectron, but was recently sold to Pleasure Craft Marine (PCM). PCM supplied alot of the tournament ski boat engines for awhile, but most have switched to Indmar now. Rumor has it that PCM is at the lower end of the scale (but they use the same GM bobtail engines). So is Crusader any better now? Who knows? If I was to chose, I go with the Crusaders.
