I need some ideas on how long I could safely run the motor without the cooler in service. I removed the ps hoses and some other things to make a repair on a cracked water jacket on the block (port side.) When replacing everything I must have bent the brass hose connection and it leaked bad. In order to test the repair I ran the engine 2x for 30 min , bypassing the cooler with 3/8" SS tubing. ( In the driveway with muffs. ) The tubing was only warm to the touch.
The question is, how long can I run at 3000 RPMs in the water to test the block repair ?
Also could a repair be made to the cooler, new ones were kind of pricey ?
Thanks for any help.
SeaRay Mercruiser GM 305 Alpha One Gen II
Steve
Steve
