dlogvine
Master Chief Petty Officer
- May 4, 2015
- 839
Boat is Ebbtide Champione 210 with v8, 5.0 mercriuser engine.
I noticed a strong fuel smell in the engine compartment after I run the boat even a little. It shows only after engine start. However I was not able to find a source of this leak. It definitely does not occur from the carburetor, since the engine does not show any traces of fuel. I looked at the fuel pump and the water/fuel separator, but it does not look like there is any. Some traces of fuel appear in the bottom of the engine compartment under the engine. I wonder if the source of the leak is in a fuel hose from the fuel tank to the pump or maybe the fuel tank hose connector and fuel gauge lever. The reason Im asking for an advice instead of simply checking the spots is the difficulty in accessing these locations. The fuel tank is completely sitting under the floor and an access hatch for the fuel tank outlet is sitting almost perfectly under the wall separating the bench seat from the engine compartment. Any advice is greatly appreciated.
