Wet Wonder
- Jul 18, 2008
- 72
(Thanks everyone that helped me solve the no spark problem in my previous thread.)
1977 Merc 351 Windsor, 233hp, 2bbl, points ign, mechanical advance, inboard single screw.
Initial problem: Not reaching max rpm range at WOT. Maxing at 3,400, then starts to stutter and lose power.
Maintenance: All new distributor components from distributor housing, springs and weights, points, coil, cap/rotor, plugs and wires. I followed Don S.'s tests for fuel system up to carb and all passed. Merc-carb just rebuilt.
Where I am now: Timing problem.
---Tonight I hit the balancer with a timing light and adjusted it to about 10 degrees at idle, per specs in the manual.
Then I hit it with the light again while bringing rpm, while in neutral and docked, to 2000rpms. It advanced 7 degrees to a total of 17 degrees. If I'm reading the manual advance curve correctly, the spec advance for 2000rpm is about 20degrees, to a total of 30degrees on the balancer.
Then I brought it up to 3000rpms, again while docked, and it did not advance at all beyond the total of 17 degrees, whch it was at with 2000rpms. The spec advance curve for 3000rpms is about 22degrees, for a total of 32 degrees at the spark.
I realize that the timing not advancing may well be the cause of my WOT/rpm problem.
So is there a problem here from what I observed with the timing light? Or does the boat need to be under load to time the advance.
Thanks,
Dave
Thanks,
Dave
