Mercruiser shifting question
webbie
Hi I have 1985 Mercruiser 260 I/O. I am currently out of water on blocks. With engine off and control all forward or all reverse the prop locks as it should. All cables operate as they should, or so it seems, and cut off switch seems to be correct in cable positions. With engine running on muffs it stalls shifting into forward or reverse from nuetral. However if I disconnect the cut off switch it will shift in forward and reverse. Is this because the boat needs to be in water so there is resistence at the prop? Or do I have other problems I should look into? I would appreciate any input Thanks, Jeff
180shabah
Re: Mercruiser shifting question
Lower shift cable is bad.
On muffs the shift interrupt should do NOTHING, when in the water there is resistance that causes the cable to flex when shifting out of gear and tripping the switch.
webbie
Thanks for you reply 180 shabah. I will order new lower cable. I'm still confused as to why it shifted when I disconnected the shift interrupt switch though.
stonyloam
Go up to the technical section at the head of this forum, and read #4 How shift interrupt works. Splains everything:)
webbie
Thanks for your reply Terry. I now have a better understanding of how the switch works. Binding cable it must be.
180shabah
Make sure you get the gaskets/o-rings you ned to pull the drive.
