Mercruiser shift cable
jasonnb
Do I need a shift cable tool to replace the shift cable on my 1976 "R" drive? It uses the old style cable that screws in from the transom side of the housing.
shakespear
Re: Mercruiser shift cable
If yours is the same as mine you have to pull the leg off of then you can undo the screwed end in the leg and pull it through<br />but don't take this as gosple
