ELLIOTT9509
- Mar 30, 2002
- 2
my searay 1986 with twin 260's Alpha 1 has a problem with one engine after running for 1 hour. It starts to run rough and miss, and I must idle it for a while or shut down.I am told it has to do with a heat sensor on the block or the manifold.Can this be repaired prior to launch in May, or must the boat be back in the water, and , does any one know what it is. <br />This only happens after 1 hour. Ichecked the water separating fuel filter, and put clean gas.
