Mercruiser power steering ball stud
Drivewayboater2
Replacing the seals on my power steering control valve. I noticed the ball stud is held stationary by the long steering tube. It is a bit scratched. I was able to clean it up an polish it with Emory paper and fine sandpaper. It moves when assembled but it’s a bit tight. Does this ball stud need to move super freely? Seems that it’s held in place and there isn’t a need for it to move like it would on an automotive steering rack application. Any guidance would be appreciated.
Lou C
If I’m thinking of the same thing the ball stud on these will move freely with the engine off and will feel more firmly in place with the engine running & the P/S pump pressurizing the system. The older ones had a grease fitting for the ball stud that just needs a few pumps of grease yearly not sure when that changed.
Lou C
Just give it a few pumps with your fingers on the rubber boot, when you feel it bulging a bit stop! You don’t want to over grease this; it can blow the internal seals inside the unit. BTW this control unit was made by Bendix & used on Corvettes (63-83) and many unibody Fords (Falcons, Mustangs, Fairlanes etc) so there are rebuild kits for the control valve but not for the hydraulic cylinder as far as I know….
Drivewayboater2
Gotcha! Will do.
hydraulic cylinder seems clean and tight
indeed…. the control valve rebuild kit I got was for a corvette. 😁
parts match up perfectly.
