Re: Mercruiser outdrive waterpump kit ??
I have an 88 Cobia Cuddy cruiser w a 470 and it was told to me that anything previous to I believe 90 was an Alpha ? Don't quote me but that it was all just Alpha no variations . The 165,170,3.7l, n 470 were all variations of the same engine but the outdrives were alpha based on year so by year of the boat you should have an Alpha. Take some photos so we can see what your into here. I am sure the guys that know a bit more than me will chime a bit later to help out here. Being an alpha your gear ratio will be 1:84:1 as well. Ratio is measured in the top end of the outdrive not the bottom. Make sure you inspect everything and if you come across anything that looks " weird" to you take a photo upload it and let the guys check it out. Welcome to iboats and good luck, Vince
