mercruiser outdrive shift problem
sjurd2001
the drive will shift into reverse fine but when i try to shift into forwards it only increases the throttle it wil not shift into gear. the shifting used to be really tight so i adjusted it and it ran fine for 2 years until now. when i shift forward it moves very freely. I was wondering if anyone could give me some ideas of where to start at the shifter or at the motor first. :confused:
mellowyellow
Re: mercruiser outdrive shift problem
welcome aboard,<br />if you post your question in the I/O section, I<br />am sure u will get lots of help. this section is<br />for outboards.<br />good luck,<br />M.Y.
sjurd2001
i have disconnected the lower cable and the throttle cable works fine. if i pull the lower cable the prop stops so it goes into reverse. however, if i push the cable all the way in it never goes into gear. the adjustment of the cable is screwed all the war in so i have no adjustment left. any ideas???
JB
Moving to I/O
Steve,<br />Your Lower cable is Shot......<br />Replace it........
Fishermark
I agree with Bondo on this one - I was having problems diagnosing a shifting problem on my dad's boat with an alpha one. It turned out that we needed to replace the cable, (and shifter assembly, but I doubt you need to do that). Now it shifts with no problems.
