Looking for some knowledge and expertise here about an outdrive failure and if something specific may have caused it. Last year, at a reasonable cruising speed, we suffered complete failure of the outdrive. Within a few seconds, it got very loud, the engine died and wouldn't restart. Upon removing the outdrive, it appears that the gears inside were basically destroyed (will attach pics). Once the outdrive was removed, the motor would turn over and run so hopefully no damage to it. We replaced the outdrive ourselves with a new one from Mercruiser (lengthy backorder from SEI and needed to get back on the water in a week). We replaced both the upper & lower on assumption that the chunks of metal from the gears in the upper were likely all through the lower unit too.
Now the questions:
1) Could something underlying have caused this or is it possible it was just "metal fatigue"? Don't want to have to shell out another $3500 if we didn’t fix the root cause here.
2) There's (to me) noticeable vibration at low RPM's, does the outdrive need aligned somehow or otherwise adjusted if replaced? Hubby is very mechanical but not an 'outdrive guy', so if there are some details/activities surrounding the outdrive replacement, I want to be sure we're checking the boxes.
Thanks for any help/suggestions any of you can provide!
Now the questions:
