Re: MERCRUISER OIL CHANGE
I highly recommend the Topsider vacuum pump available at Boat U.S. and other outlets -- works well. Cost is about $40. (As indicated, oil is pumped from the dipstick tube or similar oil removal tube, if so equipped.) Don't get the oil so hot that it burns the plastic tube. On the other hand, it has to be warm enough to flow through the small tubing. I find that the Topsider pump works on oil that is warm to the touch, but not so hot that it burns you (whatever that temp. might be). I like the idea of not handling scalding hot oil.
