Re: Mercruiser noises!!!
OK, Phil....<br /><br />..I have 3.0 140 4 cyl... same basics both GM Blocks, so here we go...<br /><br />...for starters, do me a favor remove spark arrestor on top of carb... see if carb is loose, not on base but carb loose... airhorn, etc... tell me if it is a rochester w/ mercury tag??? Vibration of these engines, will cause carb to loosen up & gasket between base of carb & middle part of carb will cause vac leak. If this is the case, pull carb, drain fuel into bucket, turn upside down, should be two phillips screws holding carb base(intake side) to middle part of carb... if these are loose you will need to rebuild carb & get carb kit from auto parts store... if this is rochester w/merc tag... look on side of carb & there will be numbers stamped in it... these are the ones you want... follow directions in kit, pick up brass float while at parts store as it will not absorb gas like old plastic/compostite orginal does. When replace screws in base... use locktite on threads... I use the color "blue" loctite... if you having any other questions, you can reach me at the address below...<br /><br />Next.....Alt... has two brackets... make sure they are both tight. Look at alt see if vibrating back & forth. Someone could have removed a bracket & engine vibrating makes it rattle... bracket bolts to block below & I believe around water pump area. Let me know.<br /><br />fone_man@bellsouth.net
