Re: Mercruiser, No Spark, SOS
thanks to BT doctor and Bifflefan - you guys were on the right track and the I was a Jac_*** to question your advice on what motor regarding the "thunderbolt" - finally got my manual and did the chart check list -
With a goos spark plug in the High voltage lead from coil and grounded to block ...
-pulled the gray tach wire off the coil - still nothing for spark
-tested the purple wire for the power to the ignition module ( Thunderbolt IV breakerless electronic timing High Energy igniton ) - power to this ok
-did the - remove green /wht wire from dist term and touching it to ground to simulate - no spark
-tested the shifter cable limit switch - it was okay - making and breaking continuity to ground depending on shift position - removed it for testing - still no spark at crank over
-lastly - checked the red/white wire coming from the ignition module - no voltage at all -
looking like the ignition module is the issue ( ?)
is there any way to check the crank sensor in the distributor with ohms or ?
Any suggestions?
Thanks again and feel free to be rough with me
