imported_JDIMIG
- Mar 18, 2007
- 3
Is there a drain hole for the cavity surrounding the shift shaft? It looks a if the previous owner may have filled and painted it over. After separating the unit from the upper housing while changing out the water pump I noticed that the area around the shift shaft boss was filled with water grit and old lube. I can see a dimple on the exterior of the unit that is about the same depth as the cavity . Is there supposed to be a drain here?
Thanks in advance!
Thanks in advance!
