Hi all, I have 1971 Sea Camper with the above mentioned shifter. It has a little round black button at the pivot point and nothing else. When I push the botton it allows the lever to move, and allows me to throttle the engine. But no shifting. It could be broken, or maybe there's a trick to it. It appears to be designed so it does both throttle and shift simultaneously. So I have two issues:
1) how do I get it to engage the shift function (no it doesn't slide out when button is pushed)
2) once I get that part figured out,/fixed, I will have a shifter that shifts into gear and throttles the engine at same time. So then how do I just give it gas in neutral at cold start up?
I'm hoping someone out there has this exact same shifter and knows.......thanks!
