rocketboy52
- Mar 21, 2006
- 26
My 74 Mercruiser 888, pre- alpha unit has the manual steering setup. While trouble shooting a leak, I found that my transom plate was cracked in half.
I have been looking all over for an identical transom plate and haven't been able to locate one. I have however found a ton of transom plates that are set up for power steering Cheap!
http://tinyurl.com/syyxb
I was raised a devout car guy, and you find me here mid-conversion to the boating religion and I must confess I don't know how Power steering is set up on boats. From looking at part diagrams I gather it is similar to a car, but I haven't been able to figure out how the wheel connects to the powersteering piston. Does a teleflex cable connect to the piston similar to a manual steering set up or would I need to buy a new dash/wheel control setup?
Below is my list of what I'm assuming I would need to make the conversion. Am I forgetting anything major or really important? Is there any reason I shouldn't convert over to powersteering?
I would need:
Power Steering pump
Pump bracket for moutning to the motor
Power steering transom plate
Powersteering line cooler
Power steering pistion
I would need:
Power Steering pump
