Mercruiser knocks but only after 3,000 RPMs under load
backonthewater
Hi all. I’m back on the water after a couple of decades of being away. It’s good to be back but I’m having an engine problem. I bought a used boat and my 2005 mercruiser 5.7 ltr developed a knock (I attached a brief video) It sounds high in the engine to me. The knock only appears at about 3,000 rpms under load. Below 3,000, it’s smooth and has power. I can’t reproduce the sound if I run it up to 3,000 rpm in throttle only mode - it only appears under load. What do you think?? Thanks!!
  • IMG_5358.MOV
alldodge
Sounds like a fan blade is rubbing. Look at the alternator and other pulleys. Take the belt off and see if there is any play
Scott06
Sounds a lot like this video I saw, and rpm seems to be similar -
in the comments owners states it was the head gasket that blew after and overheat. Do you see any evdience of water on the spark plugs
QBhoy
Do those models have a balancer shaft and wheel ? Can’t think.
Ayuh,.... The balance shaft is only in the mid-late model 4.3l motors,....
Detonation sounds likely,......
Dump the fuel filter's contents into a clear jar, 'n check for anything but clean fresh gasoline,.....
