Re: Mercruiser info needed
Good advice 69mastercraft. Why waist the money now. Wait for break in befor you get the good stuff to tweak it out. It is a must to change to oil right away,hot and a good running RPM for a couple of min's and it is ready. Good luck with the cam. Its better to do now then later plus its the cheepest H.P you can buy. If you have'nt done a rebuild befor its better to wait for your brother. There is a few things inside that if there are not installed right you will be sorry.You cant tighting a rod bolt over again after the motor has been installed. The last advice I can give is...After you get the bottom end of the motor put together and befor you put the oil pan on, go have lunch or something. When you come back check every rod and main bolts again. All it takes is one and rumm.... rumm..... BOOM ....clank...clank....clank...money,money,money!!!!!
