Emptypckts
- Jul 13, 2002
- 2
Hi Guys:<br />I have a mercruiser 4cyl. There are two ribbed hoses that hook from the outdrive to the transon mounting plate. The bottom hose burned completely thru. I don't know why. Does anyone know what this hose is for? Is it an exhaust hose? And is that why the motor got hot? Like I said it is the bottom hose the top hose is fine but I will replace both to be safe. Are there any other areas I should check? Or does this just happen when that hose fails?<br />Thanks<br />P.S Been reading other posts this is a Great Forum (YOU GUYS ROCK)for all the information and time you give to your fellow boaters.
