Mercruiser engine hot does not start and floods
Asif
I have a Mercruiser inboard 5.7 L 260 hp with 4 barrel carburetor. Boat sat for 2-years without use (has old gas). Cleaned carb and changed plugs etc. Cold engine starts fine at high rpm. Engine stalls at idle speed. When warm engine floods and does not start. What could be the problem.
Re: Mercruiser engine hot does not start and floods
Sounds like the Carb. needs More than a little Cleaning,..........<br /><br />A Complete Teardown,+ Rebuild would be where I'd Start............<br /><br />BTW,........<br />Welcome to the forums here at iboats.com.................. :)
Asif
We did take the carb out and clened every possible part. Did not rebuild it. What does rebuilding involve. What is the approx. cost of a new varburetor. The boat also went under at the dock about 3 years back. and the mechanics replaced every possible thing. Ran fine that season. Can the starter cause a hot-nostart and cold start fine condition.
Haut Medoc
I think that it would depend on how the starter sounds when the engine is warm. If it sounds different, well....JK
Don S
Are you sure it's actually flooding, or do you loose spark when it gets hot?<br />What year engine do you have, is it points distributor, or electronic (Thunderbolt IV or V)
Mile-High Mariner
What Bondo meant by "more than a little cleaning" and "a complete teardown, +rebuild" is EXACTLY that. You haven't indicated that you put any fuel stabilizer in the gas before you last used the boat, so it's assumed that you did not. Your carburetor, after sitting with old gas in it for two years, needs to be taken apart, thoroughly cleaned and cleared of the varnish that has accrued in it (gasoline will begin to degrade and deposit as a type of varnish on the metal parts within just weeks after your motor's last use); the idling and flooding problems you've described are classic symptoms of a fouled carburetor; the no-idle could be clogged jets and the flooding could be a stuck choke or a clogged fuel vent hose. If you took the carb out and cleaned every possible part, you were halfway to a rebuild. If you did not replace all of the gaskets, the accelerator pump, the carb fuel filter and some other small parts that come in a CARBURETOR REBUILD KIT (runs about $50 on average), you wasted your time. The gaskets, especially, cannot be reused, as it is impossible to avoid damaging them in the process of removing and disassembling the carb. The carburetors in these marine motors are remarkably accurate but also remarkably sensitive. Regular maintenance, including regular fuel conditioning and treatment, is very important to keeping your carb in top condition. A new carb will run you $400-500. A good quality remanufactured carb can be had for $200-300. It sounds like you have access to good skilled labor to do your own carb work - I recommend that you order a carb rebuild kit, take your carb apart again, soak the metal parts in solvent to remove the varnish, replace the appropriate parts from the kit and put it all back together and back on the motor. You'll be happier with the results.<br /><br />Re: the starter - was it not among the "every possible thing" that the mechanics replaced? It should have been the first of all of the electric accessories on the motor to be replaced after a submersion event such as you described.
